182 Touge/Tuner Build
bvnditi
Ey up!
Long-time Honda kid and recent Clio convert here.
Picked up this high-mileage machine at 170k miles with intentions of turning it into a touge toy I can reliably daily.
It's got a few nice bits on it already, like Cup shocks, Cooksport springs, a Strutbracer brace, Powerflex blacks all round, Vibra-Technics solid mounts and an ASBO-tastic Milltek exhaust.
I've additionally fitted some fun bits like a Ripspeed flip-out headunit, Alpine amp, and a set of Altezza-style taillights that will more than likely see me shot against the post by some purists, plus some team graphics to represent my overseas friends in Boneout Racing Group.
Given the age, mileage, and previous [track] use of the car, I've ordered the parts to fix the standout issues, such as the steering rack and both tie rods being completely shot, a small oil leak from the rocker cover gasket, and will be fitting some more appropriately-sized Enkei RPF1RSs in the future. Plus some Yokos for good measure.
Looking forward to learning more about these things and meeting some more Clio owners! All of the Renault owners I've met in Bournemouth thus far have been lovely, so keen to get out there. :)
Cheers!
robzracing
Welcome to Clio ownership. Sadly, unlike Hondas a cam cover leak is not an easy fix but if you don't know the service history you can tie it in to a cambelt and dephaser change.
Other than that, you'll find answers to any questions in this community and some might even be right!
bvnditi
Cheers dude! Frustratingly enough, the cambelt and dephaser was done shortly before I ended up with it, it just seems like it's been done in such a way where it's weeping a bit of oil. Looks like I might need to do the whole thing a second time from what a bit of reading tells me :ROFLMAO:
I'll have the whole thing apart on a lift next weekend as I'm replacing the steering rack and tie rods, so I can hopefully assess things in full.
Good to know that there are indeed some correct answers in the ClioSport community! Immediately doing better than my previous H-badged accomplices by the seems of it.
robzracing
It is possible that its not the cam cover leaking. The heads are prone to leak from the core plugs between the exhaust ports (I've fixed this with silicone before) and also from the seal around the dephaser solenoid on the top. Worth checking both first.
bvnditi
Bloody good to know. The car seems pretty well looked after and the oil leak's not dreadful, so hopefully that's the case.
Thankfully I'm in good stead with a specialist that races these, he's got about 14 Mk2s just sat in a barn. I'll get him summoned, and hopefully it's just a case of getting the silicon out.
Worst case, I'm a Honda owner, checking oil levels due to frequently losing the stuff's basically muscle memory at this point :ROFLMAO:
robzracing
I've been racing one of these for 13 years. I think I've had pretty much anything these engines can do thrown at me at one time or another!
bowen86
She's a beaut dude! You've done such a good job with it that it's converted me away from Hondas.
Apologies in advance if any cosmetic tweaks I make aren't to your liking 😅
Had at least 3 owners since me tbh. But I think I made a build thread on it if you go to my profile.
How I left it....
bvnditi
You've been racing Clios since I was like 10 in that case!
Out of intrigue then, given I do drive the car remarkably hard on the regular (motorsports of the after-dark variety), is there anything I should be keeping an eye out for/doing to keep the car healthy?
bvnditi
How I left it....
Had a look through your profile and found a beautiful RB & silver one, but no luck finding this one sadly! Currently fighting off a flu/fever so there's a high chance I'm just being braindead and blind there.
Someone de-track-ified it before it ended up in my hands by the seems of it then too, I picked it up off Charlie & Tim Dovey out by Dorchester.
robzracing
The gearboxes are made of chocolate so don't try and rush gearchanges. If it starts crunching into 3rd then start saving for a rebuild! And these engines love to bend valves if you over rev them or miss a gear. You can change the bottom pulley for a keyed version (from a Megan) that will stop the pulley slipping.
If you have the sump off, change the rod bolts for ARP ones. Another common failure if they get over-revved.
Other than that just keep on top of maintenance, oil changes etc and don't let it run low on oil. they suffer with low oil pressure at the best of times.
And finally, don't whatever you do look at the Pure Motorsport website. It will empty your bank account before you know it!
bvnditi
I got forewarned on the third gear issue thankfully, and I'm acting swiftly with a rebuilt box that'll be getting a Quaife before going into the car. Third does crunch, so I'll start counting down the days until I deposit my entire gearbox somewhere on the A31 (and ensure I'm still with Green Flag before doing so)
Good to know RE the engine. Keyed Megane bottom pulley and ARP rod bolts are the move then aye? I've gone from a platform known for head lift to a platform known for bottom end issues by the seems of it lol.
I usually do oil religiously every 3K, reckon that covers regular (ie, most weekends) hard fast road driving with 200tw/280tw tyres? Worth me getting an aftermarket sump?
Have unfortunately discovered the Pure Motorsport website and have accepted my fate as a 24 year-old freelance livery designer. I won't be getting a mortgage (probably ever given the state of affairs), so I can at least have a sick Clio with some Pure bits on it instead. I see no flaws with this logic whatsoever and no idea how future me could come to regret this financial decision. 🥴
bvnditi
Some small tweaks to the Clio over the weekend.
As a stopgap (and a bit of a test), I've chopped in the TSWs I've wanted rid of for a set of standard 182 alloys. These are temporary while I suss out fitment, clearance etc and trig up on a set of Enkeis from Torque GT. I've fitted a set of 195/45 Yokohama Advan V701s to them and feel like I've unlocked a tonne more potential out of the car now I'm not on Chinesium ditchfinders (who'd've thunk it??)
Furthermore, in the name of having a bit of fun, I managed to get my hands on a Ripspeed LCD flip-out headunit. Still need to sort a proper fascia panel out, but it's in, it works, and I can now pretend it's 2005 with my Pure Garage and Ministry of Sound CDs. It also plays DVDs, as pictured with a Berg Cup timeattack DVD that's almost as old as I am.
Next to-do's are to install the Alpine 4-way amp I was given, commence a manual rack conversion off a 1.2 rack with a 182 column (and replace the shot tie rods while I'm at that), and see to installing my Sparco Evo 2 bucket seats.
Ergonomically the goal's to have it up-to-date and functional for B-road twattery against EP3s, Corolla T-Sports, and the M-badged ilk that plague after dark driving these days, but I'm keen to have plenty of fun with a bit of audio while I'm at it. :)
bvnditi
Procured a thingy in the further quest for Max Power-ation for the sum of a whopping £0.
Alpine 4x-75w amp for the choons! Will be running the front speakers and tweeters off this to add to the ear ringing that the Milltek and absence of emissions equipment already gives me after five minutes.
Plan is this, a set of Alpine speakers up front and a pair of under-seat subwoofers, then call it a day with audio. 😁
bvnditi
Some recent procurements, acquisitions and ongoings.
The lip/skirt kit I ordered on the Max Power bodykit thread has now arrived, and will need some fairly heavy fettling to make fit. Given the lovely weather at the moment, that's not a problem.
My buddy also hooked me up with this steering wheel, which we're going to look at wiring cruise control and the horn into while cleaning up.
Got a new set of tie rods to fit as well, and got some gearbox fluid sourced for a bit of a service next weekend. Gonna get tackling the tricky bits while having a bit of fun. :)
Matt Cup
  Iceberg 172 Cup
Ayyy that's cool! I'm still absolutely gutted I missed out on the vented bonnet up on Renomotive. It sold a day before I got paid 😭
Forged carbon is a bit noisy texture-wise where I'm aiming for a smoothed/euro look sadly. If another vented one pops up I'll absolutely have it though 😁
Tbh I f**king hate forged carbon. So I am glad you are turning it down.
bvnditi
It feels like the beginning of a slippery slope. One minute you've got a forged carbon bonnet, the next you've got a Focus ST with a Paw Patrol livery and you're revving in school zones.
Glad I can confirm that I do, indeed, not have (completely) s**t taste 🥴
bvnditi
Speaking of questionable taste, these are off for a refurb, refresh and new hardware.
I shall be continuing my Yokohama tyre addiction with ANOTHER set of Advan V701s, given these are my style/cruising wheels.
Shall still be cruising around on a resoundingly dented silver bonnet, buuut should at least have some sick shiny wheels come early June :)
bvnditi
Going silver or doing something different?
Aye, exactly that boss. Just going with a nice metallic silver finish.
Still on the hunt for spoilers. Apparently mine's a Trophy spoiler already(?) so might end up selling that and adapting whatever spoiler I purchase to a standard Clio spoiler as a base. Got some paint peel on it to reveal it's silver underneath, so the mention of silver reminded me of that too.
bvnditi
Carbon bonnet popped back up on Renomotive! Someone in Scotland will be cursing me for having to ship it all the way down to Bournemouth, buuuut it's mine now.
Will see to making some vent covers for when the car's sat, God bless having access to a laser scanner and 3D printer.
bvnditi
Just a small update, got the bonnet ready to go in for a re-lacquer with Empire Paint once it's in my hands. ETA Thursday.
Quite excited to have the giant silver bloodclart off my car and a fancy piece of carbon! Proper. :D
MAXRUNDOWN
That's a really nice wheel.. if you're planning on using the personal horn push and it's a two wire one like mine was it will need some modification, it's really straightforward though, just need to remove the earth wire from the back of the horn push dismantle it, drill a small hole in the body so you can feed the wire through and attach it to the spring inside.
bvnditi
That's an absolutely wonderful bit of info to have. Really appreciate that dude, thank you! 😁
