Kangoo Compact (aka Racevan3)
Cheers all. Its so much better than the old hybrid setup.
Wow some good power! I'd run it at a bar, be more than enough power for the track, thing must fly 😂
Agreed mate a bar of boost is easy enough and well useable. I might add a steering wheel switch as push to pass to increase boost to 75% of high boost table if i need it to pass somebody.
Bit of a sad one but only just had chance to use this as my dad was in hospital for 6 days. I got an early call on the Sunday morning, the day after mapping to get down the hospital asap. So this was parked as bedside all week and he passed peacefully in the end after a 5 year battle from cancer. He quite liked the kangoo when i took him out in it so fond memories of that at least. f**k cancer eh.
As off work had to use this for the last couple of days on the daily. Makes a pretty good daily and reasonable on fuel when not on it. Better mpg on the bosch injectors compared to the old siemens deka dogshit.
Ive had a go of 25psi /481 and its ridiculous. The boost by gear lures you into a false sense of security as 1st & 2nd are pretty tame. Then its hang onto the steering wheel in 3rd and up trying to keep it straight. Really need to work on suspension a bit rear needs to be loads harder. Maybe neutral toe to see if that helps.
Ive also bought an Ecumaster canbus gauge to display live data. Its a rebranded canchecked mfd15 gen2 gauge. I almost hit the switch on an ecumaster 9" adu instead but i feel the extra money would be better invested in fuel hoses for the fuel system so i can go for more power, not that it needs any more that wastegate pressure😁
Plan is to remove the Aem afr and fit this in place as ecu has wideband lambda on board.
Thanks for reading!
Thanks all, appreciate the support. Knew it would get him one day but was not prepared for it to be last week.
I have refitted the ds1.11 pads to the front as it needs as much braking power as possible. Forgot how bad the brake dust is off them!
Also reason behind buying the ecumaster/canchecked gauge is due to the fuel gauge reading on the piss and it does not read right when running.
For the oem fuel gauge to work correctly it needs data from the engine ECU to Offset the flow as the level sensor intank works more like a fuel reset. Basically level sensor in tank resets a counter in the dash cluster when ign is first turned on showing correct level and the ECU counts it down.
Mine is counting down too fast, i was cruising along the m6 with half a tank in before i got to efi, then gauge drops rapidly hitting reserve in a few mins then off the bottom of the reserve. I figured i was not going to run out of fuel so kept driving, and once stopped and a cycle of the ign its showing tank level of just under half a tank.
Its not too bad on shorter journeys as level is reset often enough with stop start. Id like ecumaster to sort this if poss but i believe several people have tickets open for same issue and no solution yet.
Ive had a sniff round the TDB oem settings on renolink and cant find a way to disable the counter.
Been giving it some thought, and the plan is to intercept the wiring for level sensor at the dials and connect it to my can switchboard so Ecumaster can log fuel level, and show the level on the canbus stream on the gauge. If i disconnect the sender wiring from oem dash totally it will flag errors, so will use a dual station convertor to output correct resistance to both gauges at the same time. Other option is to add a resistor to trick oem gauge but it will render it useless, where it does something currently.
We will see how it goes. I think its doable.
View attachment 1792908View attachment 1792909
Thanks for reading!
I'm so sorry to hear that mate. I went through that last Feb. My dads was Pneumonia though. His death properly fucked me.
Thanks all, appreciate the kind words.
Updates
Motivation been low as f**k being honest but starting to get a few bits done.
Pre CSF i upgraded the oem stereo to an Alpine 204DAB. Much better even on oem speakers, also binned the knackered parrot handsfree whilst there.
Washed, as wheels were in a right state/brake dust down the sides.
Steady drive down to Cadwell and back being honest, mostly on cruise control. Lack of ac on journey down was a killer.
Had to fill up for return journey and both tesco garages i visited were out of 99 octane, so had to fill with vpower in Lincoln. £1.84ppl, dayligbt robbery🤮
390ish miles done, no issues. Great weekend.
This week i have fitted the Ecumaster mfd15 gauge. Turned out to be a bigger job than expected being honest for a simple 4 wire install.
Removed the aem wideband which was wired in really well, had to strip half the dash to remove and route cables.
Spliced into the canbus behind dials.
Loom routed/retaped.
Added canchecked rotary control..loom is very short so fitted next to dials.
First power up.
The mfd15 is a nice bit of kit. It can show all ecu parameters via canbus, support external sensors/additional stuff via canbus, shift light, external warnings etc. Loads of stuff on it, 8x pages for custom gauges.
Software for setting it up is decent too, all done on phone / wifi
I have future plans for this to read fuel level from tank and turbine shaft speed.
I have also changed the rear trims above the rear lights. One of the lads i follow on insta changed his recently and i have followed suit.
The hatch/mpv models have a reflector above the rear light instead of black plastic trim. One i spotted in Turkey last week.
Mine with plastic trims below. No idea whats happened to them, but they do not respond to any trim restoration products and needed something doing with them.
I took a gamble that the reflectors would be the same size as the plastic trims, and would fit the conventional 2 opening rear doors.
They indeed were identical in shape and size.
Fitted
Better than faded plastic for sure.
Thanks for reading!!
They look really good.
I gave up on all the plastic on the Clio. The whole lot has been painted satin black. It chips now and then but easy enough just to dab back in with a touch up pen and saves the constant f**k on of trying to keep the trim alive
Updates
Kangoo had a bit of use last week. It drinks the juice on the 870cc injectors with a heavy foot😄
It claimed its first victim the other night on the new setup. I was casually minding my own business and driving normally, when a polestar 2 rwd ev s**t thing was driving like ev do, flat out showing us how fast they are at every occasion.
On a rolling start off a set of traffic lights, i sent the polestar to Gapistan fast once in 3rd gear/1.4bar of boost, around 420-430hp setting 🤣
After fitting the alpine stereo to the kangoo, i was missing my steering wheel volume controls. I usually just sack the steering controls off with aftermarket stereo, but it was a bit of a reach for the stereo due to the lowered recaro seats.
Purchased a connects2 module that covered Kangoo2/megane etc. This was the one that had canbus and mine doesnt have a display, so even though same connection, it did not work. After a bit of digging emailing the support it turns out that i needed the mk1 kangoo one with no display bizarelly, not obvious by the listings so easy mistake to make.
I ordered CTSRN004.2 that support said would work. I was skeptical but fitted yesterday and all works well.
Stereo has been in and out loads of times so hopefully last time for a while. Royal f**k on but got there eventually and stalk works as oem which is nice.
Updates
Had the occasional bit of spark blow on high boost so fitted a new set of plugs. No stranger to this on turbo cars but you start with the basics before adding coil dwell time. The set i removed had been in since i built the engine so gaps werent as tight as they needed to be so the issue was fairly obvious. The bonus with copper bcr8es, is that they are £3 a plug so you just bin them instead of regapping.
Give it all a wipe down and a quick look over. All good.
A few pulls and can confirm no more issues up to 7700rpm limiter.
The only downside to the kangoo is that its made every other car i own feel slow. I was out in the 250 cup yesterday and no comparison on a straight line pull. Horses for courses i guess.
You running standard radiator at that power, is the cooling system standard set up, must get very hot in there
Oem megane 2 rs radiator and thermostat. Works good, always around 84/85deg on the street. On its brief run around Anglesey on hybrid turbo a few years back it was around 87deg. If anything it runs a bit cooler on the new turbo setup
Its normally always non oem rads that cause issues with cooling on the megs. Them cheap cores with the large bars..my r26 was going over 100deg on a short pull on the street with one fitted.
500hp in something the same size as my left shoe.
Sweet mother of god, this thing is awesome.
Its an absolute riot on the street mate. So much fun whether seeing off something fast or shooting past another white van man😁
Quick one
Rear brake upgrade has been on the menu for a while, the kanfoo really needs better pads on the rear but nothing available for the stock kangoo calipers as expected.
A bit of research done beforehand and the bearing is 30mm id on kangoo rear. This is identical to megane r26 rear bearing, and also same width.
Kangoo disc spec
R26 spec ( i found a better one with more data but lost it now)
As seen 274mm vs 300mm. Approx 1kg more on r26 discs vs kangoo. Note r26 disc is wider, so will increase track width by approx 12mm. This is good as i run 10mm pms spacers on the back for inner arch clearance.
Bought a spare kangoo stub axle to mock up.
Mocked up spare disc, bolts straight on no drama, abs sensor and ring fine. Dug out spare trw/r26 rear caliper and offered up.
No where f**king near. Bolt spacing is identical but miles off. The offset for the caliper carrier to disc is correct too.
Rotated caliper a bit (prob same as meg rs location) and maybe this could be adapted, but far from simple.
Thoughs all? Bit beyond my backyard engineering sadly.
Currently deciding if its worth the aggro for 25mm, extra 1kg weight. Custom pads for the oe calipers may be the way to go.
Quick one
Kangoo disc spec
R26 spec ( i found a better one with more data but lost it now)View attachment 1798426
Bought a spare kangoo stub axle to mock up.View attachment 1798416
Mocked up spare disc, bolts straight on no drama, abs sensor and ring fine. Dug out spare trw/r26 rear caliper and offered up.View attachment 1798417
No where f**king near. Bolt spacing is identical but miles off. The offset for the caliper carrier to disc is correct too.View attachment 1798418
Rotated caliper a bit (prob same as meg rs location) and maybe this could be adapted, but far from simple.View attachment 1798419Thoughs all? Bit beyond my backyard engineering sadly.
@Touring_Rob @NorthloopCup
MUST GO MY PEOPLE NEED ME
i must go my people need me GIF
So why not use the Meg R26 stub axle then? Or am I missing something?
R26 is fixed stub axle and non removable so not possible.
Meg 250 and 197 are removable, but both have the incorrect bolt spacing, so wont work on the current beam without elongating holes, its all a bit pikey.
The R26 uses that daft triangular banana bracket to offset the caliper
Would that be the bit you're missing Briggs?
Ive got both ph1, ph2 and 225 ph2 brackets. Ive tried all ph2 and no go sadly, as the 225/r26 beam mount is a different offset so caliper carrier is not central from disc.
Ill try ph1 calipers, carriers and brackets tomorrow as i have some in the garage.
Other possible options are meg 250 rear caliper brackets, or laguna 3 as some have 300mm rear disc. The issue again would be obscure calipers on the laguna so prob no pads available.
I'm 99% sure my old laguna gt had 300mm on the back. And I'm also 99% sure the pads were used on loads of different cars.
SY08DTZ if you fancy some more research.
Calipers were just normal with the electric handbrake having an external actuator mounted to the axle.
You could cut the stub axle from an r26, get a local fab shop to weld them to the kangoo axle, that might be the easiest option
The 250 uses the same offset bracket as the R26
Some of the MK3 Laguna use a similar hub to the kangoo but the caliper mounting position is different
Thats the one, are they trw calipers? I need a knackered one for mockup purposes.
Could be an option, only issue would be setting the toe/camber once welded. It would be like years ago getting oxy acetylene on a r5gtt beam and bar on the stub to add camber or toe🤣 To be fair, i could have the holes welded up on current beam then redrill for 197 clio stub axles. I think that would be a pretty easy solution.
I thought the carriers looked identical on 250. I bet something bolts up but just finding the right one.
I think they were aye. I don't think I had to replace mine so not got any lying about but @Mcaff might.
