1.4 E-type engine change
Just put a J reg 1.4 E-type engine into a 1996 1.4 E-type RT Clio.
Every things fitted fine runs perfectly apart from the fuel pump isn't getting power unless I give it a direct live feed.
Is there a different because of the age of the car the engine came out of. If so where is the easiest place to tap into the power feed for the pump so I can wire it in, Don't want to have to lay a new wire when there ones there all ready there.
