172 abs master cylinder
Car  172
ive carried out abs delete on my ph2 172 and swapped over to a cup loom.
I know the "prefered" method would be to use a cup 4port mc and comp valve and have it piped up in a split diagonal configuration
But i intend using a incar bias valve so would only be using a single line to the rear
Is there any real problem, eg cylinder bore ect, why i cant just use the 2 port original abs mc and have 1 port to the front via a tee and the other to the rear via the bias valve?
Im not sure if the abs cylinder and the non abs have different bore sizes?
Further searching reveals abs 2port cylinder to be 20.6mm and abs 4port to be 22mm
I have a 22mm 2port from a 106gti so if it fits i may aswell just use that... same spec as cup but just 2port
