172 bent rear axel
Car  www.renparts.co.uk
noticed the damaged 172 i bought has a slightly bent rear axel... noticed because 1 wheel is scrubbing.... and the gap between the end of the skirt and wheel is different on each side....
is the axel the same as the cup?
also is the same as the non disc one? so i could just bolt the discs and calipers on with the 4 bolts on each side?
anyone have any special advice fitting? it looks very straightforward tbh......
thanks
josh
The axels are the same none sport axels have a much thinner anti roll bar in them. Cups are the same but the disks dont have abs rings and they dont have abs sensors
Axle will fit off a Cup its slightly wider though not that you'll ever know.
Same as the none disk though yep Jsut need to check they have the same amount of teeth on the seleectro rings (they should do).
