172 Cup Engine Mounts
Car  Clio 172 Cup
Hi all,
I have spent the last 30 minutes looking for the answer to my question with no avail.
One of the engine mounts has gone on my Cup and I was wondering if anyone could tell me where the mounts are located so that i can find out which mount is knackered (if anyone has a diagram that would be great)
Cheer
Craig:quiet:
As you look under the bonnet mate one mount is on your left, a big rubber block
the next 3 you cant see, one is for the gearbox and is under your battery, another is between the box and the subframe and the last is whats known as the dogbone mount which is under the car
Not sure why you have had problems with the search, this has been covered loads
The dog bone is under the car near where the passenger foot well ends.
The lower gearbox mount you might be able to see by looking in the passenger wheel arch with the steering on full left lock.
I was probably looking in the wrong place. Been rushing around as it went on the way to work. Cheers for the info!
