172 cup heater questions
ok im baffled the fans in my 172 cup seem very slow even on 4 doesnt seem to be a massive amount of air blown out this maybe normal as before i drove a vw which really kicked out loads of air
but second question when i turn the knob round to recirculation for the cabin only, the fans seem to shut off no air comes out the vents at all works on every other setting but recirc?
any ideas as to why it wont work or has anyone had same issue
clio 172 cup no air con no climate control btw
thanks
Tried removing the pollen filter?
If its 8 years old and clogged up with shite it will hinder the air flow.
thanks for the advice much appreciated where is it located an is it easy to get out,
im not sure how that would affect the recirc for cabin air only but i can see how it could hinder the fan output being dragged from outside
thanks danny
ah back to the top rules that out apparently the 172 cup doesnt have a pollen filter, i jus dont get why the recirc cuts the fans out an doesnt blow air through cause surely its jus a rod that attaches to a flap to close air from outside entering , so why would the fans turn off when it does this
