Where have you got your camera mounted Phil, is it a GoPro?
I can never understand the guys who are quicker on the straight and then hold everyone up on the corners. It's not a 1/4 mile lol
If someone is faster through a corner than me I just let em pass
Not bad.
1:42 in the dry.
The complete lack of run-off at Cadwell doesn't fill you with "boundary pushing" confidence does it lol
It's a sony action camera
It's mounted on an arm coming off the roll cage. Sadly the arm has become loose and I didn't notice till I went out on track![]()
Im looking forward to going and doing Cadwell and Oulton after I move up that way, you will have to show me the lines Phil and I will see if I can keep with you in my lardy road car with rear seats and a radio![]()
Nah the hairpin is at the end of the wooded complex - you go up the mountain then swing through the right/left/right/left and theres a hairpin at the end
4 pots locked up as the track was really greasy from the tree sap and the back end swung round
Woke me up! lol
The gauges are wideband, oil pressure and oil temp![]()
Haha I'm looking forward to having someone to play with The lad I went with on Wednesday has a 500+bhp civic coupe in full race livery :|
Yeah that's where I mean , it just looks like a right hander where the bails are and then another right after. Just shows how deceptive videos are sometimes. It's firmly on the to do list in the next few years.
The hairpin is a right hander then followed by an off camber right onto the start finish straight. I think they class the hairpin and the next bend all as 'barn'.
The noise you thought/think is/was the bumper catching is the front wheels on the bracket for the bumper phil. Could even be the tyre rubbing on the arch's. Mine does the same thing. Try raising your front suspension mate.
Hrmmm I did think that but I had a look at the tyres and couldn't see any marks on them at all - though the outside of them does look a bit scrubbed which is weird with -3 degrees of front camber lol
I raised the front 10mm before we went - I really didn't want to raise it any more because it looks awesome haha but I guess handling has to come before looks
Fronts were on about 2/3rds and rears on about 3/4's
Yes - mine at some point has been hitting the chassis leg too lol
I still haven't had it back out the garage to look at the brackets yet - I'm gonna get it out this weekend and see if I can angle grind some stuff back
Probably raise it 10mm all round too try and get some suspension travel back out of it
My only criticism tbh of the KW V2's is I think if I went to R888's they would be way too soft. And I'm guessing I couldn't get stiffer springs fitted without sending them off the be re-valved or something.
Northloop - have you fitted stiffer ones on the front of yours? I felt the back was absolutely fine you could slide it about all day but I think the front could do with being a bit stiffer
email 1:
"Dear KW customer,
thank you for your email and the information.
We recommend to use a 80-170* spring instead of 60-170* supplied with the kit.
The handling should improve a lot with this.
Please contact your local KW partner for ordering this spring.
Part number is 60110047.
Thank you and we wish you a lot of fun and success with the “new setup”.
email 2:
"Hello,
unfortunately, for the rear of this car, we do not offer harder springs.
After discussing with our motorsports department, they confirmed, that with new springs on front axle and the same springs on the rear (as they have been chosen to be quite “firm”), you should get a good result on handling.
Thank you."
Arent the KW V2 dampers just Koni adjustables, ie the same as FK KonigSports?
Essentially, the stiffer the rear is in relation to the front, the less understeer you will get. On a clio, soft front/hard rear is good, hence why Whitelines are so popular.
