D Daverb Car Clio Cup Racer Apr 4, 2009 #1 Can someone help me with wiring for the 172 fuel pump. The connection is 4 pin - positive, earth, sender and something else? Can anyone look up / tell me order of the pins? Wire colour? And what the 4th wire is for? Thanks in advance.
James5_GTT ClioSport Club Member Car R5 GTT Apr 4, 2009 #2 172 Fuel pump relay - Red - perm live Yellow - ign live white - output to pump violet - trigger from ecu
D Daverb Car Clio Cup Racer Apr 4, 2009 #3 Thanks James but its the connection at the tank I need to find out.
B bmh.01 Car BMW M135i Apr 5, 2009 #5 I'll have to check to be 100% but the level sender has its own ground iirc as its not commoned up with the pump.
ditz Car LY 182 Apr 5, 2009 #6 bmh.01 said: I'll have to check to be 100% but the level sender has its own ground iirc as its not commoned up with the pump. Click to expand... yep sounds about right to me aswell
D Daverb Car Clio Cup Racer Apr 5, 2009 #7 Ah so it will be? Fuel Pump + Fuel Pump Ground Fuel Level Sender Fuel Level Ground Although maybe not in that order. Really appreciate your help guys. Its for a cup car, I need to wire up a fuel guage so trying to find right wire.
