182 engine logs
Ok I'm trying to understand some logs I took recently. They were logged using dashcommand and a 3rd gear run from low 2000rpm up at wide open throttle.
MAP sensor. I'm confused on why the figure is low upto 2500rpm then shoots up to just below 1bar. I would of thought it would have been just under 1bar as soon as I hit WOT?
Short term fuel trim. I thought this wouldn't be active at WOT?
Timing. Thought this would be a smooth increase as rpm rises.
