182 manifold on a 172
I'm in the process of buying a 182 manifold and k-tec sports cat .
Can anyone advise on the best place for fitting , how much it will cost and if i require any other parts .?
thanx in advance
How much was the 182 manifold? new or second hand?
Think I saw someone say they were quoted "under £300" on here the other day
  Ph1
Loads of info on these pages about them. Best bet is to do a search.
If you know folk in the trade its gonna help a lot. If not could be big money
  Clio 172 mk2
PM Matt Black....he may be able to get hold of one for you.
Fitting it could be a ball ache though:(
  GDI ???BHP Cliosport172
I can remember a guy on here got his fitted for about £200 takes about a day but i think they,ll need to cut up either ur existing 172cat or ur 172manifold to be able to connect the two but well worth it.
^^^got both bits ..... but reading summert about extra parts required.
Like the 182 manifold to cat kit ??? :S ......any1 else with ideas
  lift number 1 @ btm
if you have the k-tec cat it should be a direct fit, if not you need someone to shorten your 172 cat.
either way you need to drop the subframe to fit it.
I was told u didnt need to touch the subframe. Plus i was told u need to cut the flanges off both ends of the 182manifold then jus weld a bit in the middle cos the 1 i bought has the lamba sensor connection and wire i think
  Volvo S60 T5
im fitting mine soon, may just take some photo's and a possible guide.
oh and they cost over 400 quid now, renault have put prices up.
