1990 miles to decide - engine tuning
is there a specific RS Tuner map that is used if you go for cams and matched inlets?
and does anyone know what would be the best catcams to go for, is it the 428's?
428's are good on a standard engine. Dont listen to anyone advising on the 420's, well you could do, but you'll be buying standard billet cams
if its cam belt i would do cams - not cost lil bit more then get it remapped with custom map
have you made up your mind what cams to go for? or is this precisely the problem? lol
depends how much more power you want and if you are going to spend further money then it's really down to if cams are worth putting on even at this stage? That money could otherwise go towards throttles, turbo, charger etc.
Cams and custom remap or if ITB's are a future plan then go for stand alone management.
silly question or maybe not...
If I run CatCams 421 what would be the incom of pairing it up with ITB's
Cams alone gave me 10+BHP, will ITB just add its performance to it or will it "magnify" the gains ??
you cant directly compare ITB's to standard inlet tuning really. It's more the delivery and wide spread of torque with throttles as opposed to headline or peak numbers.
Negitive, mybad for quoting 240 lol but two cars made that with the same spec.
I've kinda lost intrest tbh, too busy looking at Bi-turbo conversions for the .:R32
You have a problem deciding i think , do'nt know what you want :D;) I have seen a lot of your posts over the last years coming on here and you seem to leave projects unfinished and going for another one. Ah well, when money's no prob why not !? :)
A man and his hobbies :cool:
