4 pot help
Bit of help with my calipers,.
fiat brembo 4 pots, inside bleeds fine, outside wont bleed at all (using an ezebleed)
when I crack the crossover pipe off on the outside there is fluid there.
Am I safe to assume its blocked? Can it be a seized piston?
Bleed it the old fashioned way I.e get someone to pump the pedal whilst you do it at the calipers with a coke bottle and a bit of hose, you should get a bit better force on the fluid that way and see how that goes
Nipple isn't blocked, its new, I've blown through it and its fine plus I've taken it out with the ezebleed on it and there's nothing.
ill see if I can find someone to pump the pedal for me, although I'm worried there's not enough force there
