Bleed it the old fashioned way I.e get someone to pump the pedal whilst you do it at the calipers with a coke bottle and a bit of hose, you should get a bit better force on the fluid that way and see how that goes
Sounds like the outer nipple is blocked , make sure there's fluid in the crossover pipe if that's okay take the nipple completely out and get somebody pump the pedal till fluid comes out !
