A/C NOT WORKING
hi there just bought a clio 172, 02 plate and i dont think the a/c is working very good the thing is when i press the a/c button it sounds as if the a/c is working but there is no cold air coming out of the vents so i was wondering if anybody had any idea what the problem is?
Font colour changed - please avoid the use of black.
[Edited by _simon_ on 8/8/2005 3:18:22 PM]
Have it looked-at by your dealer (if still under warranty).
Sometimes the hot/cold air mixer gets stuck (electronically controlled).
Could also be needing a gas topup.
Also check fuses (not sure if theres one specific to the a/c).
Do you hear a clicking noise when you first activate the AC ?
I had a simmilar problem with my 172, whereby you could hit the AC button but there was no click (or spindown after switching the engine off) it turned out to be a leak in the system from one of the pipes. Thankfully it was fixed and re-gassed under warranty.
From what I can remember, re-gassing normally costs about 150 notes !
You may try to have the "air recirculation button" on and try to see if there is any cold air. Also what is the air temperature you set at?
