AC/CC Q?
Car  RB 182 FF
hi all, now i might be showing my dumbness but ive just been to look at a 172 ph2. the aircon worked fine, although probably needs regassing, but should there have been a number i.e 20 degrees etc onthe display?
or is this only on CC units, or do all 172 ph2 have CC as standard?
there wasnt a number so do i have to activate the temp or does this show its bust?
sorry if this is dumb, cant find a real answer so far
cheers
the doc
Unless its a cup model, all of them should have climate control.
(Some cups came with it too)
What Phase is it, 1 or 2?
Ph1's didnt have digi climate did they?
i dont mind having to buy a new one from someone breaking etc if its broke, i just wanted to be sure i wasnt being blond and youhave to select something on the unit to then select the digital temp, im asuming is fubar'd then :(
hope im not that thick!
i used it to see if it went cold and it did so i guessed it was on, i switched the AC button so it had an orange light underneath it
Push the red button to make it hotter and see if numbers appear? It could be set to "min" in which case no numbers appear.
