AC/CC Q?
  RB 182 FF
hi all, now i might be showing my dumbness but ive just been to look at a 172 ph2. the aircon worked fine, although probably needs regassing, but should there have been a number i.e 20 degrees etc onthe display?
or is this only on CC units, or do all 172 ph2 have CC as standard?
there wasnt a number so do i have to activate the temp or does this show its bust?
sorry if this is dumb, cant find a real answer so far
cheers
the doc
Yosemite Sam
  Whichever has fuel
Unless its a cup model, all of them should have climate control.
(Some cups came with it too)
Sash
  A Yellow One
What Phase is it, 1 or 2?
Ph1's didnt have digi climate did they?
  RB 182 FF
i dont mind having to buy a new one from someone breaking etc if its broke, i just wanted to be sure i wasnt being blond and youhave to select something on the unit to then select the digital temp, im asuming is fubar'd then :(
  RB 182 FF
hope im not that thick!
i used it to see if it went cold and it did so i guessed it was on, i switched the AC button so it had an orange light underneath it
Sash
  A Yellow One
Push the red button to make it hotter and see if numbers appear? It could be set to "min" in which case no numbers appear.
