AFR wiring, baffled by instructions
Car  LY R27
just got an afr, thought it would be easy but it starts rambling on. ok so ive connected the constant live, ignition live and -ve
then theres a green wire left that says i either connect to the ecu or lambda
baffled.
heres the instructions
stage 5 is the one im stuck on
and hears the back of the sheet, talking about heated o2 sensors,
i know about electronics, but not when it asks you to do a number of different things!
thanks
BROCKY
i think that some one who has changed one would know
but iirc i had a 2 wire lambda on my clio 1.6 16v
There the worst instruction's ever lol. I take it this is a system that use's the original sensor? You should of gone wideband instead of narrow on the original.
