Car looks good mate. Bottom picture looks like the shell is flexing and the door strips are out of alignment!
Linky to guages ? I need a better set as mine are white and anoying me already.
All looking good matey. Got the turbo done then. Might do a similar thing to mine in due course as there's a little oil escaping.
Need some ceratec, nightmare squeak in traffic.
Mirrors are cool, are they heated also?
My drain for the oil leaks aswell, new gaskets / pipe and new bolts torqued up, still leaks a tinny bit.
I might out high temp sealant on it when I put it back on
@AlexW we never did measure the bolts in my cage.. I measure them at 10mm, so I'm assuming 8mm bolts will do fine?
This like pisses out, I built up oil pressure and it left a puddle of oil lol. I don't mind a very very minor leak, but this is badd lol.
I completely f**king forgot about your cage and everything. Get M10 bolts. I'll have a look to see what I can find too.
I heard you like your car to smell new.
Just a idea Alex but are you sure its leaking out of the return ? reason I say is that I noticed you took the turbo off with the oil feed pipe & were it fits in to the head there is a rubber o ring that falls off or self destructs & with it being on the pressure side oil pisses out , worth a look![]()
Silicone bends only means 1 thing....
(Terrible Intercooler pic)
Those tyrez iz mint to be da ntz like. Were out of my budget, maybe next time
Booooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooost
those tyres are epic. Had a set on mine. Pisses all over rain sport 2's!
The mirrors are not perfect fitting? I'll leave it then as Im a picky f*cker!![]()
Well I'm sure you'll has more luck convincing me about the wing mirror glass than ph2 rear lights :rasp:
Blue tinted glass would look nice on iceberg though...
Must admit I am liking your track days in a derv :race: might have to buy some new drive shafts before I consider it lol , if only you could run one on red now that would be a cheap track day ,but unfortunately the 15 dci doesn't like it![]()
That's the only problem with the 100 bhp you can only use the original drive shafts & lets just say mine are on there last legsstill dci race series could be fun lol
Id be up for an official dci race series ( or less than 1.6 diesels )
only thing I can see is crank/rod bearings making a break for it as we hammer them around lol
Still a dcijust means we get 10laps head start
You've been pretty kind about the little 8v so far. I'll stay tuned...
Should have said mate. We would have spent the 2 hours ripping them apart!
That jizz on the wing came off easy peasy
Jesus that's greasy!
Sorry I weren't available to give you a hand yesterday, I had the joys of moving.
Looks like a nice little fleet you have there.
Lol the keys.
My table is exactly the same.
