Golf 7.5R & Clio 200
				How do you remove the headlining if you dont mind me asking/hyjacking the thread? I think that looks fantastic!
			Remove A B and C pillar plastics, then remove grab handles and rear middle seat belt bracket (in roof), then gently ease it down, it held to the roof skin with a few blobs of silicone.
Lol! Just arrived mate.aren't you at work?
get some drag links and rod ends changed, Swedish shite.
Cheers mate! Well we have options on the seal tbh. If Renault don't have one I can get one sorted out off eBay. Same as the Renault item as well.@NorthloopCup
Awesome work Mark,
If Anyone is looking for a box builder I can't recommend you highly enough, absolutely faultless.
the gearing on this is going to be mental, I'm back in the country Wednesday afternoon so I'll get over at some point later this week if you get a seal
I can do mate if required.Thats going to be awesome! Love the attention to detail with it.
Ooo you do box rebuilds @NorthloopCup ?
Do you mean mtl? Yeah it's not cheap! Lol! Ok buddy. I'll be aiming for it to be back together and ready to collect this weekend. Will confirm tomorrow though, as that's when I'll be firing the lid back on it.I have order some redline mt90 at the price of that stuff a leak free box will save me a few quid,
back home now matey.
Information. Too much. Lolyeah awesome and fricking hot,
ate a 3 lb basket of chicken last night a bubba gumps at cancun airport, that was my high point but has blocked me up solid! lol
What was the tensioner like? If the exhaust was 4 degrees out that's not belt stretch mate. No way.Timing belt was due in February Anyway so I thought I'd pull the lot out rather than doing the box on my back and struggle for space with the belt.
Freds exhaust timing was 4 degrees possibly a bit stretch in the belt but it's absolutely bang on now.
Semi group n is the inlet cam only. Full group n is inlet advanced and exhaust retarded.not massively slack, it's not some carlos fandango timing that makes it go better is it?
iirc group n timing is only on the inlet and isn't 4 degrees, i checked it 5 times with a timing disc and was bang on 4 degrees advanced.
Ah right ok. Be warned - the engine won't tickover with the full Grp n timing and no remap. You need an idle speed of around 1100rpm.exhaust was out, inlet was perfect,
you may lose that tool for a week mate
Thanks for the kind words mate! Very much appreciated.First off a MASSIVE thank you @NorthloopCup for sorting out my gearbox, the amount of effort Mark has put into my gearbox has been immense,
if your average box builder had built this box the reliability of the internals would have been greatly reduced, it's down to Marks keen eye and OCD nature that has stopped me having lots of future issues, Cheers.
It's all back together and I took it for a hoon, It's absolutely frickin mental through the gears,
once I knew there were no engine faults caused by me removing or re installing I could replace the injectors and Lambda followed by resetting the adaption values with the diagnostic computer so it learns all its new parameters with the new fuel parts fitted, the reason I have replaced them is I plan to have a custom map and want solid signals to and from the ecu to make the best of it.
P!ssing out mate!,How's the selector shaft seal holding out?
Flol!!P!ssing out mate!,
Not really, dry as a bone, like I've forgot to put oil in.
Ha ha! Good idea on the buzzer as well!Yes, because I Have a private road available to me.:wink:
I have a buzzer wired up to an omex shift light, it's never seen so much action,
with the flywheel as well, it's like a bike going through the gears.
here is the graph of speed vs revs,
first column 1st gear, second column 2nd gear etc
I'm crap at updates but the car is ready for this years Hillclimb season
Just mapping and geometry left to do,
