WRX
Thanks, been up half the night. Ideas going through the skull.Let me think......yes but no ducting.
Id say yes and yes, it makes sense
Yes and yes.
Here comes the winning with pounds crew. Boooya.
How will the engine power be restricted ?
Will there be a minimium weight ?
Will there be a restriction on how many tyres for the season ?
Can you buff tyres ?
What restrictions on the gearbox and gear shift ?
If minimium weight can shell be dipped and ballast to weight ?
If standard suspension will there be a restriction on the quantity you can purchase ?
What wheel restrictions will there be ?
Steve
Wtf?!
That is what happens when people want to win and they have the budget.
In one of the other tin top series you will find ex-touring car drivers driving a couple of year old touring cars without the sequential gearbox, but with all the trick suspensions and brakes etc.
the best way to restrict power is with an air restrictor and have a minimium weight.
Steve
If you 'have the budget' then why not race in a better series, with tony ash and Ian instead of polluting the pool of people that just want cheap racing?
But there's not a great deal to gain in standard parts and ECU Steve.
That's why we're trying to keep it as standard as possible. So you can probably answer most of your questions in a negative way and be close to what we're trying here.The idea is to keep the cars as close to standard and just give them the bare essential mods that we consider necessary. The more options you have, the greater the budget has to be. Which in turn will reduce the amount of entrants. We want the maximum cars out there, not necessarily the fastest. So surely giving more options will be detrimental to the idea. If you suddenly make it so that we need another 4k on the budget then you've probably lost us all. The series is just supposed to be a competitive track day kind of thing for a bit of competitive fun. At 40, I've missed the boat for F1 now.
Exactly! I'd rather have 10 standard cars in a race than 3 fast ones. The more people slower than me out there, the more fun I'll all have.
Some people just like punching hard in a category below their weight.
Thats because people like to win, racing is fun, but not if you are constantly floating around at the bottom of the grid.
Hence people will cheat, as i said to Nick & Ollie the other day, i look forwards to hearing about you fitting secret cams & a mappable standard ecu with various maps/power limits to your car, Josh Cook boffing a sadev into a standard gearbox casing and Sam revalving his standard dampers with Nitron components. Yes it will start off as a 'cheap' series, but people will find ways to improve their cars over others ...
If people want to go that mad then let them, same goes for people wanting to do a full suspension/gearbox/engine refresh after every event. The jokes on them...
Hence people will cheat, as i said to Nick & Ollie the other day, i look forwards to hearing about you fitting secret cams & a mappable standard ecu with various maps/power limits to your car, Josh Cook boffing a sadev into a standard gearbox casing and Sam Mowle revalving his standard dampers with Nitron components.
Tbh, it will be fairly obvious if someone's that much quicker than the rest of the pack.
Unfortunately Daniel, wherever there is competition, there is cheating. Thats how it works.
Those that win the most, are quite often not the best competitors, but the best cheats lol.
What's with the running theme of punching people out/brawling in the car park?![]()
