Battery cut off will this be okay
-Dan-
Hi guys having a clear out and I have found a battery isolator switch but not sure if it will be of any use for my phase 2 172 cup as I'm not sure if this is designed for 24v cranes, same principle at the end of the day, just doesn't have the spades at the bottom for the alternator surge etc just 2 nuts for the battery wires?
This what I've got
thanks Dan
Ahh brilliant thanks :)
would it be possible to wire this into the negative side of the battery? or would you all still run through the live
Im not that fussed about alternator as the main use for the will be to keep the car secure and battery charged while up the garage :)
For that purpose you'd be as well just disconnecting the battery. Should take all of 15 seconds to do.
