battery problem
  Ph 1 172
hey guys wondered if you could help i ve a problem with one of the terminals! not sure wether its the positive or the negative but its the one where the power cables for the amp connect to. i was driving along and the car shut down whats happening is that the plug keeps coming off so the battery is no longer connected anyways of tightening this? also the battery is moving around in the holder bit by the ecu anyone know why this is happening?
  CB600FS
The battery should have a clamp holding it at the bottom mate, 13mm bolt should be in it aswell. If not you need to get one.
The actual clamp on the terminals are a 8mm bolt, try tightening it up a bit see if its loose.
