What is your obsession with putting bigger discs on it? The Westy probably has 4-pots as it's got 15" wheels and fairly little disks (and also goes a hell of a lot quicker)
You're driving a moderately quick Clio at rediculous speeds and then tanking the brakes on. Drive properly and you won't have a problem.
Pads and braided lines definately, and a set of high carbon discs will be good on top of that but not essential. AND NO THEY DON'T NEED TO BE BIGGER!!!
I've said this before.
On the road the size of the brakes is determined by the weight of the vehicle. At every corner you're coming down from the speed limit to the speed you can negotiate the corner. Down a steep grade its a matter of gravity and mass. Power doesn't come into it. You'd increase the size of the brakes on a road car if you were towing a trailer, for example.
On the track there is no speed limit so the size of the brakes is determined by the power of the vehicle because the amount of the energy the brakes have to dissipate is only limited by the amount the engine was able to add to the car since the last corner. Weight doesn't come into it.
So a trackday type vehicle like the Westfield that has an absurdly powerful engine for the size of the car also needs to have absurdly large brakes. It needs the brakes out of a vehicle of its power not its weight. And if its got to fit good brakes inside wheels that a relatively small because the vehicle is scaled down in weight and size its not surprising they use every trick they can, like using 4-pot calipers. On the other hand a Clio Trophy car doesn't need much extra in the way of brakes, just better pads, because it has very little more power than a standard car.
If you are using a Clio on the track its not its weight that's important, its its power. If you have substantially increased the engine's power you may need to substantially increase the brakes' power to because you've substantially increased the the amount of kinetic energy that has to be taken out at the end of each straight.
Its just basic physics.
