Bleeding Brakes..
Car  Tweaked Leon Cupra R
I have some new discs, lines, pads and fluid to fit (thanks to yozzasort) and want someone to clarify a few things:
nipples 8mm spanner?
lines 11mm spanner?
bleeding ABS:
front left
front right
rear let
rear right
is that correct?
Anything else i need to know..?
what size of hose do i need to fit over the nipple? 8mm id?
yep, 8mm for nipps, 11mm for lines (you'll need a 13/14mm also)
bleed sequence seems fine, go and buy an eazi bleed kit for a motorfactors
perfect mate, just wanted to clarify that..
I've never bled brakes before but i work with hydraulics a LOT at work so i guess it's the same deal.
Oh, how do i empty the system? split the hoses and pump the brakes?
