BMC CDA on valver
Right ive just bought one of these bad boys, the next question is how the feck do fit it to the valver!!
pics , info, the lots please!!!!
  Clio 190bhp Hybrid
Have posted several times so probably best doing a search. If you have teh CDA run it backwards with the pipe you get running down back of engine bay and scooped forward. Or get some longer stuff and attach to front of car.
To fit it this way battery needs pushing forward a little and battery helps hold the CDA in place too. You need some siliconbe hose and a throttle body adaptor to connect up. Adaptor needs fabricating or you can try and get the one Ktec have made for their viper.
  The Jinx
It all works out very expensive in the end. Which is why Im just going to sack it off and get the Viper kit.
But otherwise I was going to do what Matty^^^ said.
well ive got a few contacts so i should be able to get the custom 90 degrees pipe etc all done for free and hopefully get the adapter plate (with breather pipes! ;) ) incorporated for free as well!!
fingers crossed!
Grant
