Boot Split On Gear Linkage
Car  clio 16v
Hey ppl my girlfriends (this is her account sorry lol ) clios leaking slight bit of oil, tracked it down to a mauled rubber boot thats 100% split on the gear linkage gearbox side.
Obvious questions are... is this an easy job? mate has our haynes manual so cant check. wondering if it needs the linkage taking off all together. and if so will i screw up the gearing setup or not doing this? :S
Also whats the proper part name and is it costly? links welcome :cool:
thanks
Yes the gear selctor, is it not lubricated at all? its not pissing oil .Just if its been run around a lot (ie running hot) it just dribbles one or two drops thats all
its a 1995 1.8 16v i belive its a phase 1? (sorry saxo guy here)
If its just grease then it would make sense why its not pouring out then good good :) so back to replacing it, easy enough and whats the part? bad experience with garages so dont get very far trying to point out bits on there computer screens but may give em a go, think our local renault place got taken over nehow
one option is to pathch it up with a bike puncutre repair kit.
if you wanna replce it, cut the cable tie on teh linkage and putt the boot back and undo the 13mm headed nut in there, remove gear linkage, making sure you keep the plastic washer type thingy and the spindle from the middle, and then just pull the rubber boot off
Will give it go 2morra if the part arrives, cheers lunner, sadly bodging it with puncture kit wont work its a clean cut all way around. plus id feel guilty doing that lol
its difficult to succesfully put a puncture repair kit on it as its hard to clean up the surface properly even with brake cleaner.
