Re: Bren's Sunflower 172
Pulled in a few late nights to get the engine built and into the car over the past few days. Skimmed and dipped head, decked and honed block..
Removed the valves to replace the stem seals first..
New vs Old..
Re-lapped the valves..
And refitted with the new seals..
Old seals..
Quick leak test, all good!
Onto the bottom end. Quick coat of black paint..
Then onto gapping the rings..
Fitted into the bore, squared up with a piston, gap checked to Renault spec..
Repeated for the rest of the rings, then fitted in the correct order and orientation as required. Once they were correct I fitted them into the block one at a time..
Next up was the crank. New bearings were fitted to the conrods before putting the pistons into the block..
Fitted the new mains bearings into the block and used plastigauge to check the clearances, they were all within tolerance as per the Renault manual so carried on with fitting the crank properly (sorry no pics this time!). Liberal amounts of Graphogen Assembly Lubricant..
Crank in place and torqued..
Rods attached with new bearings, lubricant and torqued. Also injected sealant into the end cap and fitted the end plate..
Oil pump fitted..
Baffle plate bolted on, sump cleaned then fitted and torqued up..
New waterpump fitted..
Headgasket on then torqued the head down..
Rocker cover fitted, new cam and crank seals. Fitted the thermostat housing with a new thermostat also..
Bolted up the flywheel and then put it in the back of the BM and took it upto Brens.
Put the new cambelt kit on it, timed up and double checked. Fitted the Auxiliary setup and dropped it in...
..and thats where it stands. More soon!
New vs Old..
Old seals..
Oil pump fitted..
