by reading this thread a set of 438's will be getting ordered for my 172
438's are sposed to be virtualy the same as 428's jus ktec have treaked them a fraction to inprove the idle
Yes sorry meant 421's get muddled up with all the numbers im glad ive gone 438 just waiting for some money from a job then its going up ktec for mapping sounds good though and idling well with them in just waiting till mappings done to drive itU mean 421's not the 428's
Not really proving the cams though, more driver experience
Impreza, i have 438's so i will give you my opinion of them.
Is the money well spent on cams?
I would only suggest investing in cams if you intend to keep the car long term and are not going to sell it a month after you have the work done.
You must be prepared to sacrifice the money invested in the cams, come sale time. They don't seem to command a large premium.
Do the cams improve the clio?
Yes without a doubt, it makes the car far more exciting in the upper rev range.
Exciting is the key word, not the speed, not the 0-60, the ability to make you feel alive.
Do the cams make the car noticeably faster?
It pulls better in the upper rev range, but seems less urgent low down.
It is hard to say, as you quickly forget how the standard car performs. I am going to drive a workmates standard 172 to try an remind myself how the car used to be.
Sometimes you will be driving along, and subconsciously, you will notice the car is more urgent than you remember, that is the best way i can describe how the character of the car has changed. You will also keep deliberately dropping a few gears to feel the car above 5k.
Don't expect to be able to pull lengths on similar cars, i really struggled with a stripped/cammed 106 gti that my friend bought for £300. This was the most entertaining car i have ever been in, after i had finally caught up with him.
Do the cams put a smile on your face?
Yes, i'm smiling just thinking about them
On a quiet b road at night, you will forget about the cost. I found this is the best way to appreciate the qualities of a cheap cammed french can.
Cams will not turn the clio into a supercar, but for b road blasts they make a great addition.
My clio is more of a hobby for me than a sensible financial decision, i seem to have spent lots of money replacing parts that don't need touching.
If you have the money spare and have a passion for the clio, then do it. If you require a loan to do so, then best leave it until you can save up yourself or just buy a different car.
I hopes this helps people make their mind up about buying cams.
192bhp and 166lb are though
On what car? Wouldn't you come to the conclusion there was something wrong with said car. GT cams should make similar power to 428s, which should hit 190s (and I can't stress the last part enough) if they're fitted correctly
my price includes aux kit rather than just belt. That's the only real difference. That and distance.
Oh and it's £1349 from me
Cams £594
Cambelt and aux belt kits fitted £450
Extra labour and seals £55
map £250
(above is a guide to how I've costed it, don't take that as gospel or a mix and match menu)
^^have you posted your results online with a graph? Wouldn't mind seeing it if you have.
Btw. The car at the West Midland RR day that produced 179bhp did have approx 103k on the clock and had either worn piston rings or valve seals. Just thought I would paint a more complete picture.
176.53.oil and filter recommended too at the same time 55 quidsorry mate that sounds better, thanks ! how much do you add for dephaser too?
I had gt cams fitted to my Trophy and now has less power.But we think that's either down to faulty cams or compression . My car is getting picked up this week to sort things out as I have 2 sprints booked for the end of the month so hopefully things should be sorted by then and I can give a better report on them.
Johnny
