Geddes
								Fiesta Mk8 ST-3
				Alright, just had another attmept just now, got it cable tied round the battery area ok. I took the loose cable and put it under the panel, and just had a the end sticking out of the tow aye area to whenever i need it, and then got the battery charger and the charger cable wasn't long enough so i had to take that loose cable from under the panel and feed it through the tow eye gap for it to be ok.
So when it's finished charging, I'm debating wether just to tie up the loose cable and just tuck it in behind the headlamp area instead of putting it back under the panel every time. Just wondering if i do just tie it together the loose cable it wont cause any heat will it as there's no power going through it other than connected to the battery?
Also debating wether to get another 2.5m extenstion cable so 2 extensions joined together, will this cause issues? having part of the cable under that panel hidden away and the rest going to the car garage to the charger from the tow aye where the connecter is.
