car i bought has shite brakes
Car  R35 GTR
Has pagid fast road pads and some discs from bb performance tuning. They are shite! Pedal is rock solid due to braided hoses. Could it be anything else affecting the braking?
could be glazed. my pagid ones glazed over, and im sure i bedded them in correctly.
Re: car i bought has s**te brakes
are they really worn or glased over? or do they only work when really warm ????
they are supposed to have plenty left. They did seem to bite a bit more after a bit of use. May be they have never been bedded in properly like i did for my ds2500s.
cant you take them out if they are glazed and file them down a bit? used to work with my bikes
nice idea.lol. might do that when i get to my moms tomorrow, I really need the brakes. On my 172 that are so sharp!
Could be ur Master Cylinder if im correct, check ur Brake Fluid if its low hen im 99.9% sure it the Cylinder. Sounds like the same problem i had on the Peugeot 306. i went through about 4 bottles of Brake fluid in a period of a month not good. !
GRRRRR!!! I knew i would have problems with this car though. :)
How much are they?
How much are they?
pending on the car they cost about £200 ish but fitting it can be a right pain
lol
If they hadn't been "bedded" in then you can do it now. Its not something you only do once and never again. The whole pointof the so called bedding in process is to:
- Remove a thing layer of the pad
- Heat the pad up to an extent that it bakes out the binding chemicals
- Put a layer of pad compound onto the disc
Its recommended you do it more than just once! Especially before track days.
There for you could give the car 11 60-0's, 10 70-0's and 9 80-0's. Thats what i do to my pagids and i have never had any problems with them even when cold.
lol
I could do the same with left foot braking for a few miles?
