Changing Cat
  182FF with cup packs
So, on what level of difficulty would it be for me to change my own Cat?
I'm fairly mechanically able, but to be honest I haven't done any real mechanical stuff in years except changing my brake pads last weekend.
I've got a trolly jack, axle stands, and a decent selection of spanners, ratchets etc.
I've got a KTEC sports cat (http://www.k-tecracing.com/show_product.asp?id=1051) sat in my front room, along with a manifold to cat fitting kit(http://www.k-tecracing.com/show_product.asp?id=2335).
As far as I can guess it should be as simple as unscrewing the sensors, undoing 4 bolts, dropping out my cracked cat, bolt the new one in, screw the sensors back in, and off I go.
Had to laugh when Renault wanted £800 for a stndard Cat though :)
apart from the potential hassle of stuff otherwise being seized/corroded, there's very little room to be working on the manifold->cat joint. it's not difficult - you've just got to give yourself a lot of time and be patient
you'll need an assistant, too
lemonnobby
Same as above took me ages to do it and i work for renault i hate them. i could proberly do it by myself but its very hard.
Well, I have a load of 3in1 oil and WD-40, and my mate owes me a favour, so I think I have a plan for Sunday if the weathers no crap :)
Thanks.
  Ph1
Ask your local tyre bit if you can borrow the ramp for 10. Would be half the battle
Was amazed when mine let me use theres on a busy afternoon for free !! Health and safety, ppppffffftttttt
  DCi
was gonna say this is going to be the best idea - my girlfriends brother in law is a mechanic and has said i can bring my new exhaust round to his garage when i get it :D
  Lots of Alfas
They are quite tricky on 172s, the manifold to cat bolts and nuts are hard to get to and the cat to centre seciont bolts/nuts corrode quite badly.
Its a also a 2 man/woman job as someone needs to have a spanner on the cat down the bonnet to manifold bolts while the other undoes the nuts on the otherside from underneath the car..
Youll need a new cat to manifold fitting kit from renault and new nuts and bolts for the other end. I have the part number.
  1998 BMW e46 323i
^Indeed, new fitting kit, new nuts and bolts to attach to centre section, torx bits to remove the engine cover, assembly paste for cat-centre section, NOT manifold-cat, patience (lots of it) and an assistant with small hands, ideally a midget. I got the gf to help me.
It's not the most complex of jobs at all mate, it's just a pain in the feckin arse!
