Hi, got to change the discs and pads after 26k miles, can I assume it is striaght forward, i.e. removal of calibre is 19mm bolts x 2, disc should then slide off (once the 2 small pozy retaining bolts are removed), or do I have to remove the castlated hub nut and replace with new? appart from that is there anything else, like messing around with the abs?
Is there any technical info which could help with this sort of basic maintenance stuff on the web??
Many thanks.
Many thanks.
