Claybar Tips
  Titanium 182 FF
Is it just as easy as it sounds: Spray a good mist of QD over a section of a panel, cup the bar in your hand and then run the bar down the paintwork with medium pressure.
Do you really have to take your time or is it quite a quick job?
Any particular direction you have to move the bar?
  RB 182
Takes a while, lots of lube is required and you'll only need a third of a normal bar. It shoulds just basically glide over the paintwork with the lube.
TeZ
  Non RS : (
Yes Aslong as the surfcae is cleaned Very well beofre its a fairly easy job even with a not so mild clay bar , Tho i wouldnt advise a first timer to use a Agressive one,
DrRollo im guessing you used a fine/ultra fine one then? looked great.
  VX220 lightning
ity is pretty quick... depending on how clean your paint is it will only take about 30-40 mins to do the whole car
  106 GTi
I would not use medium pressure, you only need enough pressure to keep the bar on the paintwork. Use plenty of lube and ensure the clay is soft and keep giving it a knead to get a fresh side. Cut the bar into two of three pieces so if you drop it you don't have to through the whole bar away.
TeZ
  Non RS : (
Just dont do it like the bloke on Youtube that was posted the other day LOL.
  Titanium 182 FF
Thankyou much appreciated :)
What is the difference between a Fine and an Agressive Claybar?
TeZ
  Non RS : (
quiet easy, Agressive can be used for removing or flatterning overspray on laquer i woul get a mild Bar for general use I.E Tar and grit ..usual Everyday contam's.
