Clio 16v engine wiring loom problems
Car  Bmw M4 & Clio 16v
I recently put a new engine into my clio 16v and once all installed found that it would not run. The engine turned over but would not start. On closer inspection I discovered that the fuel pump did not seem to be powered up. And in the fuse box where there are two plugs (1 brown and 1 smaller white one - there was a wire missing from the plug)
Has anyone experienced similar problems and whats the method to solve this?
93 K reg
