Need to change the plugs on my 172 clio. Took plastic cover off and found the leads just disappear into the depths it seems ? What needs removing as i can't even see the plug caps, plugs or anything. No handbook either. Thanks
haha not to you maybe but i'm clueless mate. As far as i can see there are 7 bolts on front of manifold & two near the coil pack & a bunch of connectors and the inlet from the filter. Do all these need to come off? Will i need a new gasket ?:S Maybe i'm changing the plugs unnecesarily as checking the coil pack and pulling off each lead on the pack the engine dies down on 3 but pulling off the right hand front one makes no difference. Could it be the pack? There is a great deal of flashing when i reattach the lead but when its on the engine runs no differently { sick }. Still need a step by step removal in case its the lead { or plug which actually is brand new recently } please. Thanks Homerv6
