Clio 182 VMaxx Coilover help!
Car  182 Turbo Project
Right,
I bought a set of these from a member on here and went down to NW Performance to have them fitted. They managed to fit me in which was great at such short notice! The fronts went on fine, however the camber bolts are fooked so couldn't adjust the camber other than to what would be standard. Do people on here run any other camber? I was told that the standard camber setup is fine for road use.
The rears...:(
The springs went on fine, but there aren't any bolts or washers to mount the springs to the car, also the kit didn't come with the top rubber mounts for the shocks or any washers etc. Where can I get these from? I've emailed VMaxx but I don't know if they will be able to do anything?
Has any one got any pictures of what is at the top of the rear shocks so I can see exactly what it is I have missing?
B
