Clio dodgy Engine Mounts?
Car  Clio 1.4 16v Ph3 & ERST
Our 2004 1.4 16v Dynamique has an annoying problem. Gearchanges from first to second and, to a lesser extent, third to fourth are very difficult to make smooth.
Our Mk1 Clio had dodgy engine mounts, which, as it was a piece of crap, I just rammed some pieces silicone hose into the gaps in the mounts to make them more rigid.
Are later Clio's known for problems in this area? I do not really want to resort to such primative ways of improving the mounts on a nicer car!
It's either that or perhaps I am looking in the wrong area altogether and maybe it's a running problem?
probably the lower gearbox mount, their crap.
i replaced mine with a 172 twisted style mount with uprated Powerflex polly bushes from K-Tec, its one of the best mods ive ever done, the gearstick doesnt jump about anymore when you come on and off the accelerator, infact its solid. moving slowly in traffic in first gear is so much easyer as it doesnt kangaroo anymore!!
Tbh the powerflex bushes are probably overkill, I put the 172 dogbone mount on my megane coupe with the same engine, massive difference, fixed a known weakspot
i ran the 172 mount with standard bushes for a while and it was much better than the fucked mount but still moved a bit
if your willing to put up with the extra vibration then its deffo worth it for the bushes
ive got a 1.4 16v too and ive just had to have all my engine mounts changed the engine mount was about 65 -70 that had sheared striagh throught there was quite alot of movement on the gearbox mount so replaced that there about 23 quid and decide may as well get stabilizer aswell only 11 quid all where from renault
