clio engine swop
  iceberg 172
hey i was just wondering how do you go about putting an old clio engine in a mk 2 clio. i have looked at a mk1 engine and all the hounting seen thesame i was thinking of a 1.8 16v. but then i thought what about drive shfts hubs suspension ect, anybody got any clues. i know 5 alive have done a 1.8 rsi in to a mk 2 and a 5gtt thnks
There a few options depnds which way you want to go about it you can do the simple thing and just swop engine or swop engine and boxes or swop engine boxes shafts hubs etc.
I'd recomend a 2.0 bottom end though.
  iceberg 172
yea i looked at the 172 or 182 but ill be paying well over 1k for all the parts , so if i was to swop the engine and boxes i should be able to run the shafs and hubs does any 1 know? if this is the case i can start uprating my suspenshion ect be for i decide to do this.
You can get it for under that price plus ou do get the bigger brakes and suspenion to match the wider setup etc.
Yep swop engine and box and your cna run your hubs.
What do you mean by uprated suspension though?
  iceberg 172
so i take it that i woulde use the drive shafts of a 1.8 to my hubs then
  iceberg 172
kwl and what about the loom obv i need a loom and ecu from a 1.8 but will it all just clip in or will it need modding a little ?
  Lionel Richie
the new clio dash i doubt will work with the old clio engine, you'll have to do a lot of f**king about to get it to work in my opinion
well i woundnt like to be runing stander brakes and suspension from a 1.2 in a 1.8 lol
the brakes are the same!
Unless he has one of those ultra rare 239mm disked 1.2 16V
Loom depends how you go about it one ideas to run both ECU's or run a different ECU or get a phase 2 ecu etc.
really? Must have gone up. but then I enquired sometime ago...
£15k matt was selling full kits for but he gives a warently as such on the parts.
sorry to hi jack, edde you said you can get all the parts for a 172 conversion for under 1k, where from???
Try crashed repaired cars people have been known to buy the whole car bits for very little realy. However most of the time the gearbox are broken so need a new one.
  iceberg 172
so then it sounds like the tricky bit will be wirering up the loom tricky as in hard or tricky asin rly dificult
  iceberg 172
so wots the best way to go about the loom will the 1.8 16 v loom fit or not or will it need alot of pissing about any ideas?
