Configuation of manifold seal kit bolts?
len_beach
Car  E92 M3,172 track car
I have just picked up my manifold seal kit but want to ensure I fit everything correctly as I am guessing I got it wrong last time.
I have a Bolt, a large collar which fits around the bolt head I think, a 2nd flatter collar a silver washer which looks as if it would fit inside the flatter collar, a washer with a flatened edge and then obviously a nut.
I know it's not the best description but can anyone confirm.
Ah, that's what I was hoping would be my saviour.
Freddy four fingers or Edde maybe?
Here you go Fred:
And my guess:
The flash blocked out a washer but I drew it back in. Also, which bits go between the flanges and which are either side?
right at a gues id say
bolt / silver collor / spring / other collor / silver washer / washer / nut
Sorry to keep bumping this guys but i'm desperate to get it right this time and will be tackling it today.
nearly right, from memory all the washers go before the spring
aparrt from the retaining cap obviously
the bung is correct, that sits in the manifoldthe long bolt goes throught that, then the washers and then the spring
finally the retaining cap and nut
Fred, you're a ledge'. I've spent all morning scouring the internet for the answer.
So something like this:
