Update #21 - Rolling Road
Bit of a strange one this, as i would ideally like to have documented the inlet build first, but hey ho I have a day off today so thought i might aswell write up the day at RS Tuning - Mike can write up the airbox build later on.
Originally (earlier in the week) we hoped to run the car up to RST with the original inlet on, get it roughly mapped to take a figure, swap to our new "CAM" (Cr33do And Meek)
inlet and compare the results. Although we had trial fitted the CAM inlet in various guises the inlet was only 100% completed (off the car) at 1am on Wednesday! It felt like Fred's work ethic/shift patterns had rubbed off on me. I must stress at this point that Mike really pulled his finger out with this one - only 2 weeks ago fabrication hadn't really started!!
Anyway - luckily i have 1/2 a day off work on Wednesday so got cracking with a final test fit of the new inlet. I started at 1:30PM and by 2:30 i thought we could be in trouble! As you will read later on our inlet uses a Jenvey MR23 manifold bolted to the head. Doing up the lower 4 bolts on the head flange is a pain in the arse! My 3/8" drive bits were too big and 1/4" wouldnt reach. I had to dig out an allen key and do each bolt up 1/4 turn at a time - take into account the whole inlet and plenum was present, not just the stubby inlet! 1.5hrs later and the thing was bolted on tight. After that sesion i knew we couldnt afford the time to take it back off, replace the original, then swap over again whilst at RST. Dyno wouldnt allow for this and i didnt fancey doing it all again anyway.
The only other issue was that the injector connectors fouled on the runner back plate so i had to spin the injectors 180 degrees in the rail - not difficult. Also the silicone pipe that would form our induction kit didnt turn up in time! It still hasnt turned up! So we fashioned a s/s tube and flex hose as a temp (although quite effective) solution to get us running.
We fired it UP, no air leaks and took it for a quick test drive. All good so game on for Thursday at RST! During our test run we performed a low speed full throttle run in 2nd gear. Initially it didnt pull that well but as soon as 5k rmp came it went nuts and really pulled. It was that run that i came up with my guess of 200bhp - hardly scientific
So, Thursday came and Mike and I set off to RST; slightly nervous about what the day would bring. New engine, new inlet and lots of potential for a disaster! We arrived early and met Paul for the first time. Inital impressions were he is not one to mince his words! If he thinks something is crap he will tell you - no holding back. He was keen to see our new inlet and popped the bonnet - a few other gathered and not much was said apart from "is it air tight?" - hardly the ideal reaction :-S
The car was positioned in to the workshop
And then swiftly driven on to the rollers
We explained the spec of the engine at that it is pinking under anything other than a very light load - a sign of the engines (very) high compression. To recap - wosner 12.8cr pistons and head skimmed so much previously the cam belt required a larger pulley to gain tension!
Paul but a base map on the car a did an initial pull
The CAM inlet is suprisingly quiet (i was expecting something louder to be honest) but most importantly the engine had held together. Inital power 184bhp - Mike and I were dissapointed
Paul didn't seem overly optimitic about its potential power and said the inlet isnt doing much more than std at mid RPM but is improving higher up the rev range. At this point my previous hopes for big power were dashed and thoughts that we shouldn't have tried to make the inlet crossed my mind!
Time for a coffee and leave Paul to it...
...30-45mins later we venture back in to the dyno room and a new figure is on the screen....
.....194.3hp at 7k RPM - that's better! Mike and I were quite happy now. Even Paul was quite impressed with the figure and talked positively about the inlet
He said that our car was out performing several cars that he had previously seen with short ATP boddies - and thought it was quite impressive for a single throttle car!
Final graph
Video of one of the many dyno runs - excuse the sound quality but i did have a wopping great fan blowing a huricane over my left shoulder!
Paul continued to tweak the map to gain extra power in other areas of the rev range but the "headline" figure would remain.
So why didnt we hit 200bhp (I know its "just" a figure"). Well the answer is this. Our engine is HIGH comp, very HIGH comp. Think somewhere between 13 and 14:1! The timing advance needed to be pulled right back to somewhere around 13-16 degrees, instead of the usual 27ish to avoid detonation. Excuse me if the figures sounds wrong - i did my best to remember everything.
You could tell Paul really wanted to get more from it (and he did at one point) but ultimatley the car needs to leave his workshop safe. It's really crying out for race fuel and then 200bhp would be on the cards. We also need to fix a minor airleak between the Jenvy and the head. Currently we are using a std gasket but this will be swapped for o-rings. We have already bought the long 1/42 extension to do that. Paul recommends a new set of plugs too - Megane Sport one NGKPFR7ZTG gapped to 0.7mm. Will run that past Fred. Maybe that will see us hit 195bhp
The drive home was mostly motorway so real world testing proved difficult. However, the car pull well from low down and comes on song the higher you rev it. Personally, i think the torque curve will work well on track and overall i think Mike and I are glad to have given inlet design a shot. After all, it's our track car and this type of stuff can sometimes be as interesting as flinging around the corners
Now researching methonal injection.....
