Different standard 172 exhausts...
Edd
  Ghibli/Boxster/197T
Must have been asked before and have had a search but couldn't find anything.
I always thought Renault changed the exhaust on the 172's between the ph1 and ph2. But I bought a centre section that came off an early ph1 that won't fit my 2001 y reg ph1.
I've now got an exhaust off a ph2, will that fit??
Ed
  Lots of Alfas
Early 172mk1s had a shorter cat (the twin chamber type with 1 sensor hole) so it has a longer centre section, the difference is about an inch and a half. As yours is a later 172mk1 it will have 2 sensor holes on the cat making it longer using the same shorter centre section as a ph2.
Edd
  Ghibli/Boxster/197T
Is there more tolerance with aftermarket exhausts? They have longer hangers don't they?
Edd
  Ghibli/Boxster/197T
I suppose it's easy enough to move the hangers, if they are fixed ones. Or can you get a spacer for inbetween the cat and the exhaust?
Edd
  Ghibli/Boxster/197T
Martin_172
yeah ive not got much experiance with anything other than k-tec systems but they just have hangers that go around the box and bolt up so you can move them, im assuming the others are the same!
