discs on a 182 cup... ABS sensors aswell??
Car  Clio 182 Cup
Just ringing round to get a price for a new set of discs for my 182 cup. Most places are asking me if I just need the discs or the bearings and ABS sensors aswell? Im guessing that its the set with the ABS sensors and bearings aswell?
Rear discs? the standard advice is to buy genuine as many after market bearings fail reasonably quickly (this is based on anecdotal evidence from this site)
But yes, either way you need bearings and abs rings.
Yep you need are the ones with the bearings and abs rings on mate. You can swap the abs rings over if in good condition.
More hassle than its worth to try re use the bearings
Thanks for your comments. Sorry, I meant ABS ring, not to sure why I put sensor. I've been looking at Mintex ones. You can get front and rear discs and pads for about £150. Renault want £126 + vat just for rear discs!
I fitted mintex on mine and not had any bearing problems after 3000Miles
I just fitted genuine Renault discs and pads that I bought from a Renault dealer on ebay for £117 delivered.
