Do you guys think this method will do the trick?
  e92 + E46 M3 + Cup
So after a few reads i'm feeling ready to tackle this monster sized black lexus just still havin a debat with pad polish combo, what do you guys think of this
* Car washed with 2 bucket method & grit gaurd
* Car clayed then washed again to remove clay lube
Then on to polishing/swirl remover
So plan to use megs #83 to start with but dont know if i should use the megs w8006 foam polishing pad or would i be better using the megs w7006 foam cutting pad to begin with?? only worrys is i'm guessing the cutting pad is going to be fairly aggressive for a first time user to a machine polisher:eek:
Once thats all done i plan on using the megs #80 glaze with the w9006 foam finishing pad or should i still be using the w8006 polishing pad for #80 aswell?
Will hopefully get some pics of the lexus paint work tonight when the family get in to show the damage that poxy lexus have caused...
Thanks,
James
  Mito Sportiva 135
Use the least cutting pad and polish you have on a test area and see what the results are like, if it's not coming up great then step up to something with a little more cut.
Not used those pads or polishes myself so can't comment on those really I'm afraid.
  5 GTT & Orb'd Trophy
As you're a PC virgin would it not be better to practice on a heap before the lexus, maybe?
  106 GTi
As said use the #80 first on a polishing pad and see how it goes. Step up to #80 on the light Cut pad if the first combo does not work.
If still no joy try the #83 on a polishing pad, stepping up to a light cut pad if need be.
What colour lexus ?
  e92 + E46 M3 + Cup
What colour lexus ?
Black.... :cry:
I cant under stand how a dealer that stocks cars that are £50k & upwards can allow such shuddy valeting.... gonna have to get a sign made to put in the drivers window - DO NOT SERVICE WASH.. unless you want me to run the g220 over your face... with the cutting pad on!
  106 GTi
Is it single stage paint, lots of Black Lexus used to be, if so it should be not to bad to correct.
