2007 Clio 197
I've noticed the temperature gauge on my 197 rarely creeps above 1/4 - 1/3, so today I put some monitoring on it via the OBD port, and it seems the temperature's struggling to exceed about 65 degrees C. My commute's only 10 miles (ish), but I'd expect the car to get up to temperature in that distance. My old Scooby used to hit 80+ deg C in only a few miles..
I'm guessing it's either the thermostat or the ECU temperature sensor that's to blame. What do you reckon is the most likely?
(or, alternatively, which is the easiest to get to on the 197 to check?
