Cup 172
Recently bought some DS2500s and Brembo HC discs. Went to put these in over the weekend and hot a bit of a problem. I can get the pads into the carrier fine (nobbles filed down as per the advice on here), but when I put the caliper back into postiion, I can only secure it at the top or the bottom. Its as if the calliper wont go quite far enough into place. The pads look right (profile of the pads is in line with the profile of the discs)
Any ideas on what Im doing wrong? Had a mate pushing the caliper forwards while I tried to get the 13mm bolt in but could quite get it into position...
Ta,
Phil.
Ta,
Phil.
