Andy have you sorted yours?
nope..
I have another ECU from ECU Clinic that **should** work, haven't got around to trying it, and to be honest don't hold much hope. I've been gathering the bits to convert to PH1.
Are you running a UCH setup?
The ph1 setup is far simpler
nope..
No, I ditched all that, it's apparently all done with software in the PH2....
This is the last chance for the PH2 stuff, I have an emulator for the PH1, and an RSTuner has been on it's way for a month - another long story![]()
Make sure they don't send you a kangoo K4M map as that's the only non immob map as standard.
If it's a valid code though, that's what you want. It should work.
If it's not then the ECU shouldn't have accepted it and you'll still have a virginised ECU.
Have you had it turning over?
Yeah, think it was them that sent f0xy the kangoo map, be good to double check.
Jay low, ditch the manky ph2 stuff and go ph1 :rasp::rasp:
Anyone want to go halves on this?
http://www.tek-tronics.co.uk/product_info.php?cPath=34&products_id=59
@ Andrew, you say pin 58 is Cruise control? yet the guide says its a Engine Immob system.. now i either have the wrong diagram or you have it..
the guide is for a Sirius 32
oh pish..
have you got a guide for the 34 then?
1 → IGNITION COIL 2-3 CONTROL
32 → IGNITION COIL 1-4 CONTROL
3 --- POWER EARTH
33 --- POWER EARTH
4 → CANISTER PURGE CONTROL
8 → FAN ASSEMBLY RELAY 1 CONTROL BY CCTM
38 → FAN ASSEMBLY RELAY 2 CONTROL BY CCTM
9 → COOLANT TEMPERATURE WARNING LIGHT
39 → ACTUATOR RELAY CONTROL
10 → AC COMPRESSOR CONTROL
41 → IDLE SPEED REGULATOR CONTROL (TRACK A)
12 → IDLE SPEED REGULATOR CONTROL (TRACK B)
42 → IDLE SPEED REGULATOR CONTROL (TRACK C)
13 ← COOLANT TEMPERATURE SENSOR INPUT
43 ← THROTTLE POTENTIOMETER SIGNAL
15 --- PRESSURE SENSOR EARTH
45 ← OXYGEN SENSOR SIGNAL INPUT
63 → OXYGEN SENSOR HEATER CONTROL
64 → CAMSHAFT OFFSETTING DEVICE CONTROL
65 → GEAR CHANGE INDICATOR LIGHT CONTROL
66 --- +AFTER IGNITION
68 → FUEL PUMP RELAY CONTROL
70 → TDC ENGINE SPEED INFORMATION
72 → IDLE SPEED REGULATOR CONTROL (TRACK D)
73 --- COOLANT TEMPERATURE SENSOR EARTH
74 --- THROTTLE POTENTIOMETER SUPPLY
75 --- THROTTLE POTENTIOMETER EARTH
16 ← MANIFOLD PRESSURE SENSOR SIGNAL INPUT
19 --- KNOCK SENSOR SHIELDING
49 ← AIR TEMPERATURE SENSOR INPUT
20 ← KNOCK SENSOR SIGNAL INPUT
23 ← AC COMPRESSOR POWER ABSORBED INFORMATION
53 ← VEHICLE SPEED INPUT
24 ← ENGINE SPEED SENSOR SIGNAL INPUT
54 ← ENGINE SPEED SENSOR SIGNAL INPUT
26 --- DIAGNOSTIC
56 --- DIAGNOSTIC
28 --- POWER EARTH
58 ← ENGINE IMMOBILISER SYSTEM
29 --- +AFTER IGNITION
59 → INJECTOR 1 CONTROL
30 --- +BEFORE IGNITION
60 → INJECTOR 3 CONTROL
77 --- AIR TEMPERATURE SENSOR EARTH
78 --- PRESSURE SENSOR SUPPLY
79 --- KNOCK SENSOR EARTH
80 --- OXYGEN SENSOR EARTH
85 → POWER STEERING PRESSURE SWITCH INFORMATION
89 → INJECTOR 4 CONTROL
90 → INJECTOR 2 CONTROL
Those are the Sirius 32 ph1 pins
They differ from the Sirius 34 ph2 pins
Looks like the emulator won't work with the ph2 setup as it's a CAN BUS setup, much more complex
So if Andrew is correct that pin 58 is Cruise control then i dont have to worry about fixing that, but il remove the emulator and try it again.. guy hasnt mentioned that the emu wont work with the ecu atall..
Ye i have all that down on a word document from Jord,
Andy knows his stuff fella, and the CAN BUS stuff is coming back to me, the ECU doesn't have a dedicated immobiliser in line that you can emulate onto. Andy has the ph2 setup and has been trying to crack it for months.
Your ecu should still be virginised or have accepted the new code from your UCH+key pairing.
Maybe the reason it won't start isn't ECU related
Do you have the second ECU part like this?
http://cgi.ebay.co.uk/320-RENAULT-C...arParts_SM?hash=item5ad398e4d2#ht_1449wt_1165
Willy, what would i need to ditch this ph2 and go for ph1 style?? ..
- entire inside loom..
- engine bay loom
- Ph1 throttle body
- ecu/uch ingiton barrel the lot.
- accelertion pedal
- Throttle body (cable operated)
is that it ye? also will it all work with my ph2 engine tho?
Yes i do, which also comes with ignition barrel ..
Then I'm stumped as a virginised ECU should have just picked up the code when you turned the ignition on.
Are they all from the same car, guaranteed?
Engine Harness? is it like 2 white blocks you have to connect and its under the fuse holder in the bay? ..
ye that earth is connected as i left it in when i removed the old engine.
@ Wilky, how would i test the continuity of the loom?
Bare in minde that everything else works on the loom except headlights as i havnt plugged them in yet.
The fuse holder right hand side of engine bay would have needed rejoining as it splits when fuses are removed load a photo as these could be slotted back together wrong need photos of the side so to check the colours of the fuse holders are in correct order memrory a double green a white and a black on one side the red to the other you would have joined these when you joined the 2 looms I'm just trying to get away from ecu as if you got a full conversion of steve it should have just plug & played unless wirering was wrong.
Hope this makes sence.
You haven't activated the impact switch have you?
Whats the impact switch?
Ye i get what your saying, The fuse/relay hoder came with fuses in allready which had some damaged so these have been changed, some 50amps one did snap also replaced,
Underneath was a white connection block which connect to another which then leads into the engine bay, Il try and source a picture as i have on somewhere
here:
NOTE THAT THOSE HAVE NOW BEEN FILLED WITH FUSE'S AND ARE NOT EMPTY..
Cuts the ignition if activated
Bridge this and try it
Had an RSTuner on it? Any fault codes?
