172 cup RS2 - 330ci
Best of luck with this one!
Thanks, hopefully I'm not that unlucky to have another faulty one ;-)
No mine doesn't click mate at all.Just a quick one, does anyone's epas setup click when doing full lock?
I have checked the rack and the column mounts and they are tight, not sure what it could be unless the column itself is worn.
Korky
I was yeah. If you're wondering belt size it's a tough one and took me several different sizes. When I get home today I can let you know which one it is
I can't see that on my phone pal but I listed the part numbers in the guide I wrote.
if you look in my for sale thread at the moment there's a pic of the brackets on page 2.
@Cup_Phil: Thanks
@Korky: Which bracket should i get then? (not much to find on Ebay)
@grazo22: Can't i just butcher the wires and use some high quality 2-pole connectors? Got several lying about.
Michael
Only the more technical and Williams specific questions left!
Will the 1.2 EPAS column bolt directly to the Williams mounting holes? (looks to be the same fitment)
The UK column looks similar to the EU column (with the ignition barrel on the right hand side) - can this be confirmed?
What is the total lengt of the 1.2 EPAS column – similar to a Williams PAS column?
If you read the thread (I realise it's a bit long now though) I have a DCi rack on my 172 cup - it's identical turn-to-turn. But you have to make sure you get a proper DCi rack as the 1.2 16v ones are sold as being the same but they're more turns
I posted all the part numbers
Retrofitting a corsa column would be an utter pain in the ass compared to how easy a DIY installation it is to do it with Clio parts. Even the clio epas ecu has a proper mounting point on the cup.
Fair enough - that can be done by looping a pipe from the input and output on the 172 cup rack - filling it with fluid.
IMO though that's very very difficult to do with the rack on the car - so you'd probably still be best lowering the subframe down and taking the rack of to fit the modified pipe and then my absolutely mint low mileage DCi rack was £40... so not much of a saving
The DCi rack weighs a LOT less than the Cup rack so I swapped them over to save front end weight.
Yes - both the cup rack and the DCi rack is 3.25turns without the spacers and 2.7 turns with the spacers
I wouldn't recommend fitting them without the spacers tbh. Why would you ever need more turns to lock?
Turns lock to lock = speed of the rack
This is getting way too complicated - ignore everything you've just read about stops and s**t.
The DCi and Cup racks take 2.7 turns to go from lock to lock so are QUICK - all the other clio racks take 3.25 or more so are slower. There is no difference in the amount of lock you get just the speed you get from one to another.
You don't need to fill the rack with fluid..........if you loop the pipe over on the top of the rack and drain the original fluid out, there's enough lubrication given by the remaining oil.
Not quite mate, turns per inch of movement is the rate he means.
So if you have one rack that is 3.25 but moves the arms further than one that turns 2.7 for example, then it could still be a higher rate or same rate rack.
If you are sure that ALL mk2 dci are the same rate, then that does make it simple, did you test many to come to that conclusion though?
Well half a dozen although not totally definitive is certainly a decent sample sizeI'm sure the ones with part numbers I posted are the same rate, hence why I posted the part number.
I tested half a dozen and the ones with that part number (that came from a DCi) had the right rate, all the 1.2/1.4 ones were slower.
I cant comment on the rack, but the column is the same between the two IME. Its even the same part number on the 1.2 column I have to others have got on their DCI column, but its a DCi rack I have not a 1.2 so I cant make the same comparison.Uh-huh. That's kinda why I spent the time going to 2 scrap yards and an afternoon at renparts trying all the racks they had on the shelves
Because Fred was convinced the DCi was identical to the 1.2 16v
and everyone was telling me they were all slower, and I really didn't want to fit a slower rack to the Clio, but I still think the looped pipe thing is a bit of a hacky way of doing it (though I know technically it's fine)
Yeah I'm using a 1.2 16v column&ecu on a DCi rack.
The problem with DCi racks was finding one that hadn't done 150k. The first few I tried had loads of play in them.
Yes I know. But the racks move the same distance in both directions. Hence why the inner and outer tie rods are all the same length.
So more turns = slower rack.
No I'm not sure - I'm sure the ones with part numbers I posted are the same rate, hence why I posted the part number.
