Renault Laguna Coupe
Jon - in answer to your txt about spring fitting - Jon16v supplied the following wisdom a while back:
"jack the rear up as high as it will go, you can basically pull the springs out - keeping the two rubber parts that sit on top and below the spring.
the fronts a little harder.
wheel off, bonnet open jack up side.
Undo bolts securing strut and undo top mount, remove - use spring compressors on spring, completely remove top mount remove spring, uncompress - so easy "
The full thread is at:
http://www.cliosport.net/bbs/ShowThread.asp?ThreadID=97985477&TopicID=10
Mike.
