Hi guys,
Recently bought a Clio 1.2 16v 2003 and plugged my obd scanner to find that it was registering fault code p0440 what is this and how can it be solved and also after doing a few hundred miles I've noticed a buildup in "Mayo sludge quite thickly on the oil filler cap and oil filler tube however no other symptoms of Head gasket failure I presume this is just condensation from previous owner only doing short trips. Also the sunroof leaks is this a common problem is it likely to be drain tubes or the seal?
Many thanks
Llandjack
Many thanks
Llandjack
